an alpha release (very early development release for preview) of the the upcoming GarageSale 8.4 is available for you from this address:
https://downloads.iwascoding.com/downloads/GarageSale_8.4a4.dmg
What’s new in GarageSale 8.4
- GarageSale no longer prompts for choosing a payment method if “Managed Payments” is activated for your eBay account (requires OAuth token, see above)
- If you are using profiles for shipping or returns, GarageSale will no longer prompt you to select a Payment profile (requires OAuth token, see above)
- Order section: New context menu entries in the order outline view to change order state (e.g. “shipped”) for selected orders
- GarageSale will prevent you from starting auction-style listings, when the auto-cancel feature is enabled
- Attributes window: enabled ‘autocompletes’ option for certain attributes (e.g. ‘Artist’ attribute in LP/Records section)
- Synching: re-worked conflict algorithm to reduce the number of times the Conflict window appears
- added AppleScript command to manipulate shipping weights
- various crash fixes
The GarageSale team
