fixed mixed-up menu items in the new “Order Status” submenu in the outline view context menu of the orders section
GarageSale generates a ‘mobile summary’ from the first 800 characters of your listing description when uploading listings, which does not include GarageSale’s version identifier string
the ‘Reveal Original’ command is available from the overview context menu (middle area) in the listing section
the number of images used in a listing is shown in Editor mode
What’s new in GarageSale 8.4
GarageSale no longer prompts for choosing a payment method if “Managed Payments” is activated for your eBay account (requires OAuth token, see above)
If you are using profiles for shipping or returns, GarageSale will no longer prompt you to select a Payment profile (requires OAuth token, see above)
Order section: New context menu entries in the order outline view to change order state (e.g. “shipped”) for selected orders
GarageSale will prevent you from starting auction-style listings, when the auto-cancel feature is enabled
Attributes window: enabled ‘autocompletes’ option for certain attributes (e.g. ‘Artist’ attribute in LP/Records section)
Synching: re-worked conflict algorithm to reduce the number of times the Conflict window appears
added AppleScript command to manipulate shipping weights
various crash fixes
text entered in the “user properties” area of the inspector is now searchable
new smart group rule for searching “user properties” content
Great!! Very useful!! Maybe add a little more spacing between the small/tiny icon and the first digit???
Works great for Smart Group listings.
Can you allow the “Reveal Original” command from the overview context menu (middle area), for any and all listings, not just Smart Group listings?? Even if the listings did not come from a Smart Group?? This way I can select several listings (by clicking a folder) on the left side, then use the middle area to narrow down the number of selected listings (by using the popup menu or the header to sort listings and select a sub-set), then I could “Reveal Original” to select the new sub-set of listings in the left side listing overview.
Well… This change is not quite working correctly nor taking into account Text Snippets nor expanding them.
Here is my description in GarageSale Editor Mode, all plain text:
{{textblocks.Description_Header}}
With Coal Load.
{{textblocks.New_Line}}
Knuckle Couplers.
{{textblocks.Description_Start}}
This is Brand New Never Used. It is in New/Excellent condition. See photos of actual item. What You See Is What You Get.
{{textblocks.Description_Footer}}
Here is the correct description in eBay desktop from a GarageSale 8.3 generated listing:
Knuckle Couplers.
Here is the description in eBay desktop from GarageSale 8.4a6:
Knuckle Couplers.
{{textblocks.Description_Header}} Knuckle Couplers. {{textblocks.New_Line}} {{textblocks.Description_Start}} This is Brand New Never Used. It is in New/Excellent condition. See photos of actual item. What You See Is What You Get. {{textblocks.Description_Footer}}
Here is the description (mobile summary?) and the “full description” in the eBay Mobile app from GarageSale 8.4a6:
Your linked listing seems to be an older one that doesn’t have the “item summary” added. I think you posted the wrong link. This should be the correct one:
I have GarageSale_8.4a6 on my Mac, 11.5.2 Big Sur, and it worked fine with Alpha 5 until “Ebay Payments” couldn’t be accessed. I can’t refresh my token from preferences. My listings won’t get approved due to the lack of an ebay payment setting.
I updated to Alpha 6 hoping it would fix it but it’s still grayed out. I also restarted and reset anything I could think of.
Any help is appreciated.
VinnyH PS: I did go back to 8.3.6 to get some items up tonight, no problem going back
Why can’t you refresh your eBay access token? Do you get an error?
With GarageSale 8.4 it’s required to refresh the eBay token as desribed in the “General Notes about GarageSale 8.4” section in the initial post at the top.
In the Alpha version when I go to GS preferences and click to refresh the token it opens the login page for ebay. After I enter my password, that page closes. It does not go to the approval page, as usual.
I tried it multiple times while reopening and refreshing the browser, ebay and GS, It did not get me to the approval page.
When I went back to GS 8.3.6, it worked fine, as it had in the past.
Vinny
If I am not mistaken that’s exactly how it works with the new authorization method. That extra approval page is no longer required.
In the GarageSale preferences > Accounts it now shows the token expiration date. If you see a date there, your token should be refreshed and fine!
But, when I go to start listings,the ebay payments area is faded and not accessible. When trying to verify during “Start Listings” I continued to get the “No payment selected” error. This stopped me in my tracks.
Vinny
Could you post a screenshot so we can see what you see?
Later after work I will add screenshots to this thread. I use GS at home mostly.
Vinny UPDATE: I realized that I no longer have the Alpha version loaded to attempt screenshots. Basically after putting in my password on the ebay popup page, it closes and doesn’t show the option to confirm or deny that access.
Back in GS, the option to set payments is grayed out and cannot be clicked on or accessed. If you click “Start Listing” the error comes up as needing to choose a payment option, which I couldn’t.
That’s fine, too. It’s now reflected in GarageSale, if eBay’s managed payment is used. When using eBay’s managed payment feature you can’t define your own payment options.
That’s odd, you’re right. We’ll have a look at this.
It might be required to renew the eBay token completely:
Remove your eBay account from the GarageSale preferences > Accounts, restart your Mac and then re-add your eBay account in GarageSale 8.4alpha.
If this won’t help, please give this a try:
Quit GarageSale if running.
Open the macOS “Keychain Access” application and enter “GarageSale eBay Account” in the search field. (If you don’t find anything try it with “ebay token”.)
Right-click on the eBay account token in the Keychain and select “Delete”.
If done, restart your Mac, start GarageSale 8.4alpha and add/refresh your eBay access tokens in the GarageSale preferences > Accounts.
