the sixth beta release (a feature complete version for preview and testing) of the upcoming GarageSale 8.4 is available for you from this address:
https://downloads.iwascoding.com/downloads/GarageSale_8.4b6.dmg
We initially had more features planned for the 8.4 version, but eBay is now requiring a different kind of access token (OAuth, which is only supported in GarageSale 8.4) for the product search API.
This is forcing us to release a fixed version quickly to all users. Otherwise our users would remain stuck with a broken feature, something we’d like to avoid.
What’s new in this beta
- the ‘Show Listing in Browser’ command in the outline view works with multiple listings selected
- reliability improvements to synching
What else is new in GarageSale 8.4
- fixes “Product Search” feature, which broke through an eBay API change
- Order section: New context menu entries in the order outline view to change order state (e.g. “shipped”) for selected orders
- GarageSale will prevent you from starting auction-style listings, when the auto-cancel feature is enabled for such a listing
- Attributes window: enabled ‘autocompletes’ option for certain attributes (e.g. ‘Artist’ attribute in LP/Records section)
- Synching: re-worked conflict algorithm to reduce the number of times the Conflict window appears
- added AppleScript command to manipulate shipping weights
- various crash fixes
- text entered in the “user properties” area of the inspector is now searchable
- new smart group rule for searching “user properties” content
- GarageSale generates a ‘mobile summary’ from the first 800 characters of your listing description when uploading listings, which does not include GarageSale’s version identifier string
- the ‘Reveal Original’ command is available from the overview context menu (middle area) in the listing section
- the number of images used in a listing is shown in Editor mode
- added new Preferences settings (under eBay > Advanced) that prevents automatic switching to ‘Live’ view when listings are started
- ‘Condition description’ attribute can be removed from a listing with the Revise command
- fixed font size issues in Shipping options panel
- fixed problems with importing specifics from XML files
- when GarageSale is already running, images dragged onto its Dock icon will get added to active listing
- fixed a crash when category search returned a single result (e.g when searching for a category id)
- category panel now displays category id when the category was deleted by eBay
- category id for deleted categories is shown in Inspector
- fixed an issue where a click on the “shipped” checkbox in the orders section was not reflected on eBay
- fixed possible crash when Attributes panel was open when GarageSale was about to quit
- the Listing CSV Import panel remembers what separator character (coma, semicolon) was last used
- the ‘Copy Listing Link’ command in the outline view works with multiple listings selected
The GarageSale team
