GarageSale 9.0 Beta 12 Released
The twelfth beta version of GarageSale 9 is available for you to download from the link below:
https://downloads.iwascoding.com/downloads/GarageSale_9.0b12.dmg
What’s new in Beta 12
  • tweaked logic of barcode type determination
  • tweaked mechanism reporting
  • more performance improvements when selecting a larger number of items
What’s new in GarageSale 9
  • run custom JavaScript to process listings in your library
  • Launch control can show errors returned from custom JavaScript validation function
  • main window toolbar is customizable
  • supports eBay’s new API to download attribute and category data, as some of the attribute APIs currently used by GarageSale will be shutdown by eBay
  • you can attach videos to your listings
  • you can send discount offers to watchers of your listings in bulk
  • you can assign colored tags to your listings and orders and filter for tags using smart groups
  • added an SKU generator function for listings and inventory objects
  • right-hand inspector’s width can be changed
  • reports: shipping costs are no longer added to profits if you didn’t fill in ‘actual shipping costs’
  • reports: added ‘Total fee’
  • part fitment information is imported from eBay via the “Import from My eBay” command
  • messages received eBay’s messages system can be flagged
  • the ‘read’ state of eBay messages is now transmitted to eBay
  • you can now import items from GarageSale Scout, GarageSale’s iOS companion app, as inventory items
  • a listing’s variations can be manipulated via AppleScript
  • downloads and displays fee for usage of eBay’s payment service
  • the Font size of Outline View can be adjusted (through System Preferences)
  • new preference settings brings up panel for inserting specific attributes into new listings
    Orders section: replaced “Feedback Left” checkbox with “Leave Feedback” button, when no feedback was left yet
  • GarageSale will show a warning when you are trying to open 10 or more listing links in your browser
  • Listing section: shipping options strings shows dimensions and weight when calculated shipping is used
  • Orders section: added context menu item to change sort order for subsequent sort commands
  • Listing preview: return policy label updates correctly when return policy changed
  • image upload operations show the name of associated listing in the ‘Activity’ window
  • the new ‘tag’ property on listings is now accessible via AppleScript
  • GarageSale’s Preferences window remembers it’s position
  • added count badge when dragging items in outline view
Synching
Licensing during Beta phase
Cost
  • macOS 10.12 or later
that fixed it. There is no spinning ball on a 7,700 listing folder. It scrolls in an instant and allows me to move around easily. Also no problems on smart group folders.
The JavaScript error reporting seems to work now. I could not get the hang, after a few tries.
I’m still having issues with this…
These 2 listings both have Condition New, and Barcode. One gets Error: The UPC field is missing. The other does not. I THINK I should be able to Relist both listings with a blank Barcode, and have the UPC field on the eBay website show “Does not apply”.
2 Exported listings.gslisting.zip (3.5 MB)
This listing: “Lot of 20 …”:
Can not Start this listing with Condition New. Get Error: The UPC field is missing.
If Start listing with Condition Used, then OK.
If then change Condition to New, and Revise. Get Error: The UPC field is missing.
Lot of 20 Alloy Forms 2014, 6’ Wooden StepLadder Kit,Metal Detail Parts,HO Scale.gslisting.zip (4.9 MB)
