The fifth beta version of GarageSale 9 is available for you to download from the link below:
https://downloads.iwascoding.com/downloads/GarageSale_9.0b5.dmg
What’s new in Beta 5
- added workaround for selection issue in outline for pre-macOS 11.0 systems
- the new ‘tag’ property on listings is are now accessible via AppleScript
- added experimental ‘evaluate listings’ AppleScript command
What’s new in GarageSale 9
- reports: added ‘Total fee’
Synching
Licensing during Beta phase
Cost
- macOS 10.12 or later
