The ninth beta version of GarageSale 9 is available for you to download from the link below:
https://downloads.iwascoding.com/downloads/GarageSale_9.0b9.dmg
What’s new in Beta 9
- fixed quirks with condition popup in listings section
- improvements to customizable toolbar
What’s new in GarageSale 9
- run custom JavaScript to process listings in your library
- Launch control can show errors returned from custom JavaScript validation function
- main window toolbar is customizable
- reports: added ‘Total fee’
- the new ‘tag’ property on listings is now accessible via AppleScript
- GarageSale’s Preferences window remembers it’s position
Synching
Licensing during Beta phase
Cost
- macOS 10.12 or later
