The second beta version of GarageSale 9.1 is available for you to download from this URL:
https://downloads.iwascoding.com/downloads/GarageSale_9.1b2.dmg
What’s new in Beta 2
- newly added user properties show up immediately in Listing or Inventory Item Inspector
- fixed localization for new Order section smart group properties
- aligned order of ‘Reveal in Hierarchy’ & “Show Original” context menu items
- leaving search mode via the ‘Reveal Original’ command clears search string
What’s new in GarageSale 9.1
- user properties in are available for inventory items
- inventory items are accessible from JavaScript
- the ‘Reveal Original’ context menu command works for listings displayed in search results
- added a ‘Show In Hierarchy’ context menu command for listings displayed in search results, allowing you to quickly jump to groups enclosing your listing
- the ‘Restrict Results To …’ command in search field popup now works for Smart Groups
- pressing the tab key works as expected in user properties table
- added “Show In Finder” command to image context menu in Editor mode
- when revising a listings VAT rate on eBay, without having a vat rate selected in GarageSale, the VAT rate is set to zero on eBay
- eBay messages: GarageSale properly downloads the ‘read’ flag from eBay for already downloaded messages
- added ‘Seller Account ID’ smart group property in Orders section
- added ‘SKU’ smart group property in Orders section
- Synching: fixed reporting of oversized images when uploading to server
- fixed an issue where GarageSale would stop uploading listings on certain Macs when the screen lock become active
- GarageSale now prevents the insertion of duplicate keys into the user properties table
- Condition popup in inspector updates when condition is changed from Preview
- improved handling of images with unusual color spaces
- macOS 10.12 or later
The GarageSale team
