GarageSale 9.1 Beta 4 Released
The fourth beta version of GarageSale 9.1 is available for you to download from this URL:
https://downloads.iwascoding.com/downloads/GarageSale_9.1b4.dmg
What’s new in Beta 4
  • added an ‘Apply Remaining Quantities’ button to the Variations panel, which sets your current quantities to what’s available on eBay. This lets you make changes to your quantities while considering what’s already sold.
  • the ‘Erase Deleted Items’ command preserves the current outline view selection
  • the ‘Pro’ Preferences section shows the date and time when the listing counter will be reset
  • GarageSale will no longer delete an listing’s subtitle on eBay when revising it, when the listing has not subtitle in GarageSale and the subtitle field has not been selected for revision
What’s new in Beta 3
  • updated German localization
What’s new in Beta 2
  • newly added user properties show up immediately in Listing or Inventory Item Inspector
  • fixed localization for new Order section smart group properties
  • aligned order of ‘Show in Hierarchy’ & “Reveal Original” context menu items
  • leaving search mode via the ‘Reveal Original’ command clears search string
What’s new in GarageSale 9.1
  • user properties in are available for inventory items
  • inventory items are accessible from JavaScript
  • the ‘Reveal Original’ context menu command works for listings displayed in search results
  • added a ‘Show In Hierarchy’ context menu command for listings displayed in search results, allowing you to quickly jump to groups enclosing your listing
  • the ‘Restrict Results To …’ command in search field popup now works for Smart Groups
  • pressing the tab key works as expected in user properties table
  • added “Show In Finder” command to image context menu in Editor mode
  • when revising a listings VAT rate on eBay, without having a vat rate selected in GarageSale, the VAT rate is set to zero on eBay
  • eBay messages: GarageSale properly downloads the ‘read’ flag from eBay for already downloaded messages
  • added ‘Seller Account ID’ smart group property in Orders section
  • added ‘SKU’ smart group property in Orders section
  • Synching: fixed reporting of oversized images when uploading to server
  • fixed an issue where GarageSale would stop uploading listings on certain Macs when the screen lock become active
  • GarageSale now prevents the insertion of duplicate keys into the user properties table
  • Condition popup in inspector updates when condition is changed from Preview
  • improved handling of images with unusual color spaces
  • macOS 10.12 or later
The GarageSale team
Dumb question … I didn’t load Beta 3, Im on Beta 2 I believe. I can just load Beta 4 and skip Beta 3 right, 4 has Beta 3 in it I assume?
Yes… The latest Beta always includes changes from the previous Betas.
