GarageSale 9.2 Beta 2 Released
GarageSale 9.2 Beta 2 now is available for you from this URL for download:
https://downloads.iwascoding.com/downloads/GarageSale_9.2b2.dmg
What’s new in GarageSale 9.2
  • starting in January 2023, eBay will require third-party clients to cryptographically sign certain API requests. GarageSale 9.2 implements these new requirements.
  • added a ‘Number of Views’ smart group rule in the Listings section
  • the ‘Select eBay Video’ command is always available from the preview context menu
  • the Attributes panel no longer sorts suggested values alphabetically when they only consist of numbers (e.g. shoe sizes)
Cost
  • macOS 10.12 or later
The GarageSale team
Already implemented my first smart group using this. Thanks!
Me too!!
Thanx!
The “Updating Index…” took 3+ minutes, with NO progress bar updating…
How about adding the Auto-Delete of Deleted Listings (106478) and Deleted Orders (17050)???
:slight_smile:
This is a new behavior with 9.2b2. Mine indexed for a couple minutes as well and I have never seen that before now. I was going to force quit because it never ran that long previously
