GarageSale 9.2 Beta 6 now is available for you from this URL for download:
https://downloads.iwascoding.com/downloads/GarageSale_9.2b6.dmg
What’s new in Beta 6
- the duration popup menu in the Inspector behaves correctly when changing the duration for multiple listings
What’s new in Beta 5
- fixed a bug that prevented listing from being auto-canceled, if they were created by auto-canceling and auto-restating another listing
What’s new in Beta 4
- fixed cosmetic issues badges with the account’s window toolbar
What’s new in GarageSale 9.2
[[if attr.name=="Author"]]
[[endforeach valueLoop]]
[[endif]]
[[endforeach attLoop]]
Cost
- macOS 10.12 or later
The GarageSale team
