GarageSale 9.2 Beta 8 now is available for download from this URL:
https://downloads.iwascoding.com/downloads/GarageSale_9.2b8.dmg
What’s new in Beta 8
- improved multi-selection behavior for duration, store categories, and condition popups in inspector
What’s new in Beta 7
- can import item attributes with multiple values from CSV files
- values need to be separated by a
|character - the eBay category needs to support multiple values for the imported attribute
What’s new in Beta 6
- the duration popup menu in the Inspector behaves correctly when changing the duration for multiple listings
What’s new in Beta 5
- fixed a bug that prevented listing from being auto-canceled, if they were created by auto-canceling and auto-restating another listing
What’s new in Beta 4
- fixed cosmetic issues badges with the account’s window toolbar
What’s new in GarageSale 9.2
[[if attr.name=="Author"]]
[[endforeach valueLoop]]
[[endif]]
[[endforeach attLoop]]
Cost
- macOS 10.12 or later
The GarageSale team
