The final version of GarageSale 9.2 is now available for download from this URL:
https://downloads.iwascoding.com/downloads/GarageSale_9.2.dmg
What’s new in GarageSale 9.2
- improved multi-selection behavior for duration, store categories, and condition popups in inspector
- improved re-selection behavior after changes to trigger smart group updates
- improved performance when pasting ‘Design Setting’ component into multiple listings
- can import item attributes with multiple values from CSV files
- values need to be separated by a
|character - the eBay category needs to support multiple values for the imported attribute
- extended JavaScript commands to manipulate and delete variations
- added new icon in Listing outline view when both, auto-restart and auto-cancel, are enabled
- fixed a bug that prevented listing from being auto-canceled, if they were created by auto-canceling and auto-restarting another listing
- fixed cosmetic issues with the number badges with the account’s window toolbar
- various performance improvements
Cost
- macOS 10.12 or later
The GarageSale team
