when using business profiles, the selected profile can changed from the Preview
fixed cosmetic issues with the new profile popups in the Listings Inspector
when downloading listings states from eBay fails, GarageSale will now retry more often with a longer delay between retries. This should increase the reliability of the auto-cancel and auto-restart features in case of brief internet outages
What’s new in GarageSale 9.3
introduces a single checkbox for toggling eBay ‘Business Policies/Profiles’ in the Listing inspector, instead of having 3 separate checkboxes in the Shipping, Returns, and Payments panels
Kristian, Paul, and Ilja
Also new in GarageSale 9.3 is the Preview mode:
The Preview mode has been modernized and cleaned up. To make the changeover easier for you, here is an overview of the most important changes:
• Better mimics the current eBay website, giving you a better idea of what your uploaded listing will look like.
• You can now select your profiles for payment, shipping, and returns directly from within the Preview. (The new „Use Profiles“ checkbox in the Inspector has to be activated first.)
• Unused options no longer clutter the view. Addable options are revealed as you move the mouse over the Preview.
• Easily add or remove an option.
• Use the new “+” menu in the top right corner to easily add a secondary category, product information, or a subtitle.
• Improved image gallery: Now displays up to 24 images and offers a new „Quick Zoom“ feature that lets you quickly inspect your photos.
• More appealing: Bigger font size and images when viewed on larger screen.
• Other useful information, such as eBay site, item location, SKU, is displayed in tags at the bottom. Hover over them to reveal more details.
I like the updates and the larger font size in the title! Can these microscopic fonts also be made larger? At least as big as the small folder font in the side bar
Unfortunately, your screenshot has very low quality.
Are you saying that in the duplicated listing there are parts missing in the Preview?
The original listing is fine though?
Could you export the original listing by using GarageSale’s Export command in the File menu, compress (zip) that exported listing and post it here or send it to the GarageSale support? This way I can try to reproduce the issue here.
I keep fonts, colors, and Media panes open all the time as I am editing. The problem is they sometimes close or move around. Adding them below the SKU blank area would be a quick 1 click place to edit as you are working. This way grabbing pictures would also be simple as they would be right there. Going up to the top to open the panes creates an extra step in the work flow.
Thank you, I imported your listing here in GarageSale 9.3b2 under macOS Ventura and also tested it under macOS Catalina.
Your listings looks super-fine to me, even the duplicated listings. Please see the attached screenshot.
• Please also let me know what version of Safari you have installed. Just select “About Safari” from the “Safari” menu in Safari.
For macOS Catalina the latest Safari version 15.6.1 if I am not mistaken.
Oh wait, you are using your own custom listing design (“La Primula Rossa”), right?
Most likely some code in your design breaks elements in the upper Preview area.
I am pretty sure it has to do with the CSS code used in these listing designs. Can you send me one of them, so I can try to figure out what’s causing the issue?
