the GarageSale 9.4.2 is now available for download from this URL or via the built-in updater:
https://downloads.iwascoding.com/downloads/GarageSale_9.4.2.dmg
What’s new in GarageSale 9.4.2
- fixed an issue that prevented sending offers to watchers
- fixed an issue that prevented buying GarageSale licenses on macOS 14 Sonoma
- fixed an issue that could cause GarageSale to hang when opening the ‘Attributes’ panel
- when using eBay’s Picture Service additionally to GarageSale’s image service, the listing page will show all 24 in the eBay provided slideshow
- when using the ‘Add’ button in the new image picker on macOS 13, the added photos are sorted by the order they were selected by the user (unfortunately does not apply to drag & drop)
- the order section will show the location entered in the ‘inventory item’ linked to the listing
- added a ‘Barcode’ column when exporting listings into CSV files
- fixed a bug that prevented the ‘location’ field being imported from CSV files into inventory items
- fixed a bug that prevented changing a listing’s user properties from JavaScript
- added image rotation commands to the Listings menu
Kristian, Ilja, and Paul
