fixed title search for orders (requires rebuilding your index to work for existing orders)
improved performance when search option “Hide Items in Trash” is used with a lot of items in the trash
fixed an issue in the ‘Launch Control’ window when the “Run only local verification” settings was enabled
What’s new in GarageSale 9.4
New Features
on macOS 13, GarageSales uses the System’s new and improved media browser window, which provides quicker and more comprehensive integration with the Photos app
listing attributes can be edited in directly Preview mode
will not display listings fees in the ‘Launch Control’ window for private sellers on eBay Germany
shipping services can be accessed through JavaScript, allowing for [custom validation rules] in the ‘Launch Control’ window (Validating scripts when launching listings)
Launch Control Window: can start listings, even if some listings received errors during verification
Preview: attribute area visually now even more similar to eBay page
Preview: Changes to location details are now reflected properly
Performance Improvements
faster smart group updates
Bug fixes
fixed tab restoration after selection change in inspector
SKU Generator: the ‘Start Value’ field on subsequent invocations takes ‘Step size’ into account
Kristian, Paul, and Ilja
Do searches include text from listings or title only? I am getting listings in searches that absolutely DON"T have the word searched for. This is not new but an old issue
A bit more info, if you delete the attribute info using the pop out editor then you will not be able to edit it with the preview editor after. Don’t delete the whole attribute, just empty the text box that holds the attribute value. I can make another video if needed.
I am on macOS 10.14.6. The issue is not specific to any listing, it’s all of them, even a newly created listing. I created a new listing… blanked out the attribute values using the pop out editor, then was unable to add new values in the preview editor. I’ll attach the exported listing.
Thanks for the effort, I’m just realizing how old macOS 10.14 really is. I guess it’s time to update my hardware. Aside from that, I’ve been able to work around this by modifying my workflow. Being able to edit in preview is really a nice update.
