Beta 14 of GarageSale 9.4 is now available for download from this URL or via the built-in updater:
https://downloads.iwascoding.com/downloads/GarageSale_9.4b14.dmg
What’s new in this beta
- added location string to inventory items
- can now filter by user properties in inventory smart groups
What’s new in GarageSale 9.4
New Features
- on macOS 13, GarageSale uses the System’s new and improved media browser window, which provides quicker and more comprehensive integration with the Photos app
- listing attributes can be edited in directly Preview mode
- will not display listings fees in the ‘Launch Control’ window for private sellers on eBay Germany
- shipping services can be accessed through JavaScript, allowing for [custom validation rules] in the ‘Launch Control’ window (Validating scripts when launching listings)
- Launch Control Window: can start listings, even if some listings received errors during verification
- Preview: attribute area visually now even more similar to eBay page
- Preview: Changes to location details are now reflected properly
- moved to a new API for selecting eBay charities
Performance Improvements
- faster smart group updates
- improved performance when search option “Hide Items in Trash” is used with a lot of items in the trash
Bug fixes
- fixed tab restoration after selection change in inspector
- SKU Generator: the ‘Start Value’ field on subsequent invocations takes ‘Step size’ into account
- fixed title search for orders (requires rebuilding your index to work for existing orders)
- fixed an issue in the ‘Launch Control’ window when the “Run only local verification” settings was enabled
- fixed an issue with the add button in the video upload panel
- stability improvements when fixing object hierarchy in DB
Kristian, Ilja, and Paul
