the first beta version of GarageSale 9.6 is now available for download from this URL:
https://downloads.iwascoding.com/downloads/GarageSale_9.6b1.dmg
What’s new in GarageSale 9.6
You can press the control and optionkeys in preview to see how the link will look like when uploaded to eBay.
Kristian, Ilja, and Paul
