the second beta version of GarageSale 9.6 is now available for download from this URL:
https://downloads.iwascoding.com/downloads/GarageSale_9.6b2.dmg
Wats’s new in Beta 2
What’s new in GarageSale 9.6
You can press the control and optionkeys in preview to see how the link will look like when uploaded to eBay.
Kristian, Ilja, and Paul
