the third beta version of GarageSale 9.6 is now available for download from this URL:
https://downloads.iwascoding.com/downloads/GarageSale_9.6b3.dmg
Wats’s new in Beta 3
- Link Listing command: improved handling of listings with non-ascii characters in their title
- the ‘Apply current Changes from eBay’ command can import missing images from eBay
- added ‘startDate’ to listing JavaScript commands
- fixed a crash when using the ‘Paste’ command in the return policy panel
Wats’s new in Beta 2
What’s new in GarageSale 9.6
Kristian, Ilja, and Paul
