I have a Smart Group shown below in the photo.
Yea, yea, yea, I know it is a strange Smart Group…
The movie shows opening the Smart Group, and click cancel or hit escape key closes Smart Group. Good.
Open Group, click OK button. Button hilights for a second then unhilights and does nothing. From this point on, the window can not be closed. Clicking Cancel or OK button does nothing, hitting escape key or return key does nothing. GarageSale must be force-quit. Bad.
Open Group, press return key. Application Crash. Crash Log below.
This is still a problem in GS9.6b8. See movie above. If I have the “Days Since Start is less than 0” rule, I can not close the Smart Group window. I have removed the “Days Since Start is 0” rule.
I finally figured this one out. The bug was caused by combining ‘Days Until Auto Completion’ and ‘Days Since Start’ rules in the same predicate. Those rules need to be dynamically re-written to match the entries in the database for the current time, and the code which does that didn’t expect a combination of such rules.
