added a new ‘Days Since Start’ smart group rule for listings
What’s new in Beta 4
added ‘startDate’ to listing JavaScript commands (this time for real)
fixed Dark Mode issues in JavaScript editor
What’s new in Beta 3
Link Listing command: improved handling of listings with non-ascii characters in their title
the ‘Apply current Changes from eBay’ command can import missing images from eBay
fixed a crash when using the ‘Paste’ command in the return policy panel
What’s new in Beta 2
added ‘watchers’ and ‘views’ to listing JavaScript commands
What’s new in GarageSale 9.6
new ‘Insert Link To Listing…’ feature (see below)
displays eBay avatar images for seller accounts
added keyboard shortcuts for image rotation commands in Editor mode
improved eBay fee preview on eBay Germany
increased feedback comment length to 500 characters
Kristian, Ilja, and Paul
Perfect. Made up a new smart group and this is perfect. I was wondering if a smart group “library” could be made so if I loose a smart group ( which is easy to do by accidentally hitting “delete” to remove a listing and I loose the whole smart group) so recreating a new smart group is super fast or making a new smart group is faster when adding a new parameter to the list. I am getting quite an extensive Smart Group list and have come to daily rely on them for using GS.
What about extra menu commands for exporting and importing smart groups from/to disk? You could backup your favorite smart groups and shared files with other users?
OK… I reverted back to 9.6b4. Then I rebuilt all indexes, etc.
Things are working good again, now. I THINK I know what was going on…
I THINK adding the new 9.6b5 Smart Group rule “Days Since Start” (possibly “Days Since Start is 0”???) to an existing open/expanded Smart Group, or a new Smart Group that was open/expanded seemed to cause all my problems.
Ah!!! I had both of my Smart Groups containing the new “Days Since Start” rule “expanded/open”… And it seemed like some actions (Stop/Start/Relist) would change the contents of those “open” Smart Groups (adding new listings to the Smart Group during in the middle of the Stop/Start/Relist command) and the current selection would get “lost” and the action would get very confused and crash.
I had 2 expanded/open Smart Groups with the new “Days Since Start” rule that would get populated or de-populated during a Stop or Start or Relist operation which would change the listing ordinal order of the current selection.
