the sixth beta version of GarageSale 9.6 is now available for download from this URL:
https://downloads.iwascoding.com/downloads/GarageSale_9.6b6.dmg
What’s new in Beta 6
- fixed bugs in the new 'Days Since Start" smart group features
What’s new in Beta 5
- added a new ‘Days Since Start’ smart group rule for listings
What’s new in Beta 4
- added ‘startDate’ to listing JavaScript commands (this time for real)
- fixed Dark Mode issues in JavaScript editor
What’s new in Beta 3
- Link Listing command: improved handling of listings with non-ascii characters in their title
- the ‘Apply current Changes from eBay’ command can import missing images from eBay
added ‘startDate’ to listing JavaScript commands- fixed a crash when using the ‘Paste’ command in the return policy panel
What’s new in Beta 2
What’s new in GarageSale 9.6
Kristian, Ilja, and Paul
