the eight beta version of GarageSale 9.6 is now available for download from this URL:
https://downloads.iwascoding.com/downloads/GarageSale_9.6b8.dmg
What’s new in Beta 8
- empty smart groups can be duplicated
- additional fixes for new ‘Days Since Start’ smart group rule
What’s new in Beta 7
- smart groups can be duplicated
- added warning when deleting smart groups to prevent accidental deletion
- fixed ‘Bold’ button in Preview mode’s formatting toolbar
- improved check mark image in Lauch Control for better Dark Mode appearance
- fixed recognition of changed ‘reply to’-links in eBay Message to eBay GarageSale’s reply window
What’s new in Beta 6
- fixed bugs in the new 'Days Since Start" smart group features
What’s new in Beta 5
- added a new ‘Days Since Start’ smart group rule for listings
What’s new in Beta 4
- added ‘startDate’ to listing JavaScript commands (this time for real)
- fixed Dark Mode issues in JavaScript editor
What’s new in Beta 3
- Link Listing command: improved handling of listings with non-ascii characters in their title
- the ‘Apply current Changes from eBay’ command can import missing images from eBay
added ‘startDate’ to listing JavaScript commands- fixed a crash when using the ‘Paste’ command in the return policy panel
What’s new in Beta 2
What’s new in GarageSale 9.6
Kristian, Ilja, and Paul
