GarageSale 9.6 (final release) is now available for download from this URL or the built-in updater:
https://downloads.iwascoding.com/downloads/GarageSale_9.6.dmg
What’s new In GarageSale 9.6
General
- new ‘Insert Link To Listing…’ command lets you add links to other listings to your description
- the zip code from your listing’s location settings (‘Advanced’ tab in the Inspector) is now used for calculating shipping rates when using calculated shipping
Preview
- updated Preview to better match the look of eBay’s latest website changes
- location settings can be opened from package details window
- location and package settings can be opened from Preview
- fixed ‘Bold’ button in Preview mode’s formatting toolbar
Smart Groups
- added a new ‘Days Since Start’ smart group rule for listings
- added ‘Days Since Order Received’ smart group rule in the Orders section
- smart groups can be duplicated
- added ‘Order Date’ as sorting option for order smart groups
- added ‘Start Time’ as sorting option for listing smart groups
- added warning when deleting smart groups to prevent accidental deletion
Scripting
- added ‘startDate’ to listing JavaScript commands
- fixed Dark Mode issues in JavaScript editor
Misc
- listing overview mode uses ‘eBay gallery’ image instead of listing’s first image
- fixed wrong title for “Delete Smart Groups” command when multiple smart groups are selected
- improved check mark image in Lauch Control for better Dark Mode appearance
- fixed recognition of changed ‘reply to’-links in eBay Message to eBay GarageSale’s reply window
- the ‘Apply current Changes from eBay’ command can import missing images from eBay
Kristian, Ilja, and Paul
