GarageSale 9.7.2 is now available for download from this URL or the built-in updater:
https://downloads.iwascoding.com/downloads/GarageSale_9.7.2.dmg
What’s new in GarageSale 9.7.2
- Preview Mode: Fixed a problem where the title field would unexpectedly change to a small font size
- fixed an issue that could cause GarageSale Pro subscribers to be logged out
What’s new in GarageSale 9.7.1
- Preview Mode: fixes an issue introduced in GS 9.7, where the Preview would steal the keyboard focus when a new listing is selected
- fixes a Preview related crash on the macOS 14.4
- added a ‘filter by title’ field at the bottom-left of the main window
- Preview Mode: Title field wraps lines when running out of space; You can now use the tab key to quickly switch between most input fields
- Preview: Fixed an issue with the ‘condition description’ field
- XML Import: added work around for sandbox restrictions when importing images from local disk
- JavaScript API: added ‘useSKU’ command to listing
- search results are now displayed hierarchically, showing the names of their enclosing groups
- when switching between modes (listings, orders, inventory items), the content of the search and filter fields is restored
Kristian, Ilja, and Paul
