GarageSale 9.7 Alpha 5 (an early preview release) is now available for download from this URL:
https://downloads.iwascoding.com/downloads/GarageSale_9.7a5.dmg
What’s new in Alpha 5
- Preview Mode: Title field wraps lines when running out of space; You can now use the tab key to quickly switch between most input fields
- Preview: Fixed an issue with the ‘condition description’ field
- XML Import: added work around for sandbox restrictions when importing images from local disk
- JavaScript API: added ‘useSKU’ command to listing
What’s new in GarageSale 9.7
- search results are now displayed hierarchically, showing the names of their enclosing groups
- added a ‘filter by tile’ field at the bottom-right of the main window
- when switching between modes (listings, orders, inventory items), the content of the search and filter fields is restored
- fixes a Preview related crash on the upcoming macOS 14.4 (now in Beta)
Kristian, Ilja, and Paul
