the final version of GarageSale 9.8 is now available for download from the URL below or the built-in adapter:
https://downloads.iwascoding.com/downloads/GarageSale_9.8.dmg
What’s new in GarageSale 9.8
- Fixed warning about http eBay/EPS image URLs
- Fixed crash on macOS versions older than 14.4
- Fixed a possible crash when authorizing your account with eBay
- Fixed crash when launching listings from search results with “move after launch” option active
- Fixed a possible crash when leaving search while having a group with multiple entries selected
- Fixed a possible crash when uploading videos to eBay
- Fixed error when videos will expire sooner than the item you want to list
- Fixed issue with downloading and parsing (return) business profiles from eBay
- Fixed bug were synching stopped in certain scenarios
- Fixed bug in the JavaScript interface, that let users set invalid item specifics
- Fixed some “Best Offer” error messages
- GarageSale no longer prevents you from starting auction listings with the “Best Offer” option
- Added basic support for accessing orders via JavaScript
- Added “Find Combined Orders” command to the “Orders” menu, that finds orders that have been combined into new orders on the eBay website, and moves those (no longer needed) orders into the trash
- Added an optional toolbar item in Orders mode for the “Find Combined Orders” command
- Added an optional toolbar item for the “Reveal Original” command (for use in smart groups)
- While downloading listing states from eBay, GarageSale will download the flag “Can Send Offer to Watchers” and display it in the “Status” inspector for running listings
- Added a new smart group rule “Can Send Offer to Watchers”
- When invoking the “Send Offer to Watchers” command while having listings selected, which have the “Can Send Offer to Watchers” flag already enabled, GarageSale will skip downloading the list of eligible listings and lets you send offers right away
- “Send Offer to Watchers” window: Presets are properly saved
- “Send Offer to Watchers” window: Previous selections for account, site, percent/amount and the last message text is preserved after relaunching GarageSale
- “Send Offer to Watchers” window: Changed minimum (5%) and maximum (99%) percentage
- Text blocks can contain macro language commands, like [[item.title]]
- The macro command [[item.conditionDescription]] is correctly expanded when used in the description
- The status of the Relist toolbar item in the listing sections gets updated after ending a running listing
- GarageSale will ask for read permission when importing images via AppleScript to work around macOS sandbox restrictions
- Added AppleScript example “Create Listings from Images In Folder”
- Added AppleScript example “Append Text to Selected Listings”
Kristian, Ilja, and Paul
