the second beta version of GarageSale 9.9.1 is available for you to download from the URL below:
https://downloads.iwascoding.com/downloads/GarageSale_9.9.1b2.dmg
What’s new in GarageSale 9.9.1 Beta 2
- ‘paidDate’ and ‘createdDate’ for order transactions are exposed via JavaScript
- JavaScript function
listingAdded()in validate script is called when the listing is successfully started - JavaScript function
listingRelisted()in validate script is called when the listing is successfully relisted - JavaScript function
listingRevised()in validate script is called when the listing is successfully revised - added warning panel when marking orders as paid
- shows sum of BIN prices in overview mode
- fixed several crashes
- fixed issues with opening the built-in Help window
- added warnings before deleting attributes
- added setting to control rounding behavior for calculated shipping package dimensions (GarageSale menu > Settings > eBay > Advanced)
Kristian, Ilja, and Paul
