GarageSale 9.9.1 Released
GarageSale 9.9.1 is available for you to download via the built-in updater or from the URL below:
https://downloads.iwascoding.com/downloads/GarageSale_9.9.1.dmg
New Features / Changes
  • adds an “Only start Searching on Return” option to toolbar’s search field menu to improve usability on slow Macs and/or large databases
  • shows sum of BIN prices when several listings are selected, sum of order prices when several orders are selected
  • you can now implement the callbacks listingAdded(), listingRelisted(), listingRevised() in your custom JavaScript validation scripts
Improvements
  • added warnings before deleting attributes
  • added warning panel when marking orders as paid
  • added setting to control rounding behavior for calculated shipping package dimensions (GarageSale menu > Settings > eBay > Advanced)
  • paidDate and createdDate attributes of order transactions are exposed via JavaScript
Bugfixes and Crashes
  • worked around an issue with the built-scheduler and missing category metadata
  • fixed issues with opening the built-in Help window
  • fixed several crashes
If you should run into any issues with release, or have other feedback, please let us know.
Kristian, Ilja, and Paul
Feedback…A simple ask?
A running listing should never be allowed to be put in the trash. I need/want GS to track all my running listings so no running listings should be allowed to be moved to trash. I made a wrong key punch and later found some in the trash.
And a not so simple ask… A menu bar button to close all open “GROUPS”. Some of my groups are getting long and smart groups contain all running listings so scrolling up to the top to close a folder gets long and cumbersome. After GS does work in a folder GS leaves the folder opened so scrolling to the top takes some work sometimes.
Not a solution for this problem but did you know that you can close/open all groups inside a group by clicking on the triangle icon of the parent group while holding down the alt key?
Yes but if you are at the bottom of the stack you have to scroll the whole way to the top to get the triangle icon and hold down the key. If GS leaves all or many folders open that is a lot of scrolling to get to the top
The “Home” and “PageUp” keyboard keys should also work…
ARGH!!! Where have those keys been all my life??? What kind of wizard invented them? I am but a novice…Pro tip of the year award.
Would it be sufficient for you if we added an option to prevent the Trash from be emptied, when it contains running listings.
Yes, That would prevent loosing a running listing that inadvertently found its way into the trash. I try to remember to check before emptying trash but you never know when in a hurry there might be one in there.
How about a Smart Group rule for “in Trash”, then we could make a Smart Group showing running listings in the Trash…
