GarageSale 9.9.2 Beta 3 Released
Beta 3 of GarageSale 9.9.2 is available for you to download from the URL below:
https://downloads.iwascoding.com/downloads/GarageSale_9.9.2b3.dmg
What’s new in Beta 3
  • added a new preference settings 'Prevent deleting running listings"
  • fixed an issue where loading the preview might set the listing duration to 30 days
  • fixed an issue where item specifics where not correctly removed when multiple listing were selected
  • prevents error panels from popping up when eBay server are not reachable when automatically updating listing states
What’s new in Beta 2
  • users can hide entries from the shipping carrier popup in the orders section (scroll down to the bottom of the carrier menu)
  • when invoking the “Copy Listing Link” command for multiple listings while holding down the option/alt key, a blank line is inserted in between links
  • various crash fixes
What’s new in Beta 1
  • when selecting an order, it’s corresponding listing is updated with current data from eBay
Kristian, Ilja, and Paul
Nice! I had to try it and works great. No more accidentally deleting running listings. Thanks for your continued work.
