Beta 3 of GarageSale 9.9.5 is available for you to download from the URL below:
https://downloads.iwascoding.com/downloads/GarageSale_9.9.5b3.dmg
What’s new in Beta 3
- fixed an issue in Preview mode where the starting bid field stopped accepting values
What’s new in Beta 2
- fixed an issue in Preview mode when double-quotes are used in attribute values
What’s new in Beta 1
Added “Scroll to new destination” checkbox to “Move Selected Items To” panel
Added “Remove Non-Mandatory Details” command to attributes popover drop-down menu. It’s also available in Preview mode. A warning appears when you select this command so that you don’t accidentally remove details.
Launch Control window remembers last position (on main screen only, sorry)
When switching between sections, last selected item is correctly restored when in smart group
The filter field in the bottom left of the main window works a tiny bit faster
Kristian, Ilja, and Paul
