GarageSale 9.9.5 Beta 5 Released
Beta 5 of GarageSale 9.9.5 is available for you to download from the URL below:
https://downloads.iwascoding.com/downloads/GarageSale_9.9.5b5.dmg
What’s new in Beta 5
  • updated French and Italian translations
What’s new in Beta 4
  • fixed a crash when using the “Move To” command on groups while search results were displayed
What’s new in Beta 3
  • fixed an issue in Preview mode where the starting bid field stopped accepting values
What’s new in Beta 2
  • fixed an issue in Preview mode when double-quotes are used in attribute values
What’s new in Beta 1
  • Added “Scroll to new destination” checkbox to “Move Selected Items To” panel
  • Added “Remove Non-Mandatory Details” command to attributes popover drop-down menu. It’s also available in Preview mode. A warning appears when you select this command so that you don’t accidentally remove details.
  • Launch Control window remembers last position (on main screen only, sorry)
  • When switching between sections, last selected item is correctly restored when in smart group
  • The filter field in the bottom left of the main window works a tiny bit faster
Kristian, Ilja, and Paul
What is the difference between “filter” and “search”? They both seem to bring up the same listings.
Your Dock button changed! I like it! Smaller but easier to see with the white background. It is more compatible with the other buttons that have been upgrading even on my old OS.
The “filter” field at the bottom of the outline view is a “Filter by Title” feature. It bypasses the search index, and performs a literal, case-insensitive string search. It will find patterns of special characters and numbers, which you might not have been able to find using the index based search function. It can also be used to further narrow results obtained by using the regular search function.
“Filter by Title” explains it much better than just “filter”. It just filters the titles and not text in the whole listing base.
