The second beta version of GarageSale 9.9 is available for you to download from the URL below:
https://downloads.iwascoding.com/downloads/GarageSale_9.9b2.dmg
What’s new in 9.9 Beta 2
- fixed an issue where newly added person and document information for product safety settings was not immediately saved
What’s new in GarageSale 9.9
Major Changes
- added support for ‘Parts Compatibility’ for eBay Italy
- added support for new ‘Product Safety’ settings soon required for business sellers shipping to EU countries in certain categories (this feature requires GarageSale Pro)
Other Improvements / Changes
- Calculated shipping: if the package weight or dimensions values use a decimal digit, GarageSale will send the next bigger integer value to eBay
- videos, that have been previously uploaded to eBay, and have since expired, are no longer shown in GarageSale’s video panel
- the ‘Payment Instructions’ field has been removed as payment is handled by eBay now
- the "Payment Instructions Sent’ checkbox has been removed
- the ‘Restocking fee’ field has been removed from the Return Policy settings, as this option has been deprecated by eBay
- added icons to commands in the ‘Window’ menu for easier navigation
Bug Fixes
- package dimensions are now revised on eBay when revising the “Shipping Options” box was selected in the revise panel
Notes about synching
If you are using the Mac-to-Mac synching feature of GarageSale Pro, please note that GarageSale 9.9 uses an updated data schema, which older versions of GarageSale cannot handle.
Therefore, once you have uploaded data to the sync server using GarageSale 9.9, older versions of GarageSale will not be able to access your data on the sync server, unless they are updated.
Kristian, Ilja, and Paul
