Using 9.8.1 (1677)
- Search for an item
- Select the group that the located item is in
- Right Mouse Click. Move Selected items to…
- GS Hangs
- Force quit required
- Repeatable Operation
Cheers
Using 9.8.1 (1677)
Cheers
Thank you, I was able to reproduce this and will create a ticket.
BTW: For me just quitting GarageSale worked (no force-quit required).
Probably another issue on my DB.
