Garagesale won’t allow me to create new products as it will not allow me to select which category a product is in . Also for existing lists the categorys on all listings are shown as unknown on the latest version if garagesale 7
It seems that your eBay category data is out-dated and needs to be updated.
Please give this a try:
- Open the GarageSale preferences > Accounts. Click on “Refresh Token” to refresh your eBay access token.
- If done, select one of the listings in question and open the category browser. In that browser click on the sprocket icon to update the category data.
If you’re still using GarageSale 7 make sure it’s the latest version 7.0.21 (or consider upgrading to GarageSale 8).
Thank you seems to be sorted now!
