I did a complete system restore from 2 days prior to the crash: (16th Dec).
Everything has loaded correctly except GarageSale which still cannot get past those error messages:
Sorry, if there are parts missing from the database, there is not much we can do. I have a copy of your GarageSale.leveldb that you sent me a while back, but it’s probably missing a good chunk of your recent listings. Couldn’t you download that copy from Dropbox?
Thought I would try and trick the DB by copying a good file to all the 1500 missing files:
#!/bin/bash
oldfile=$1 #$1= command line arg
ext=".ldb"
goodfile=“4288180.ldb”
for num in {1…300}
do
oldfile=$(( $oldfile + 1 ))
newfile="$oldfile$ext"
cp ${goodfile} ${newfile}
done
Well my script worked but, not surprisingly, GS crashed whilst trying to re-index on startup.
Oh well. Worth a crack I guess.
