I’ve been using GarageSale with no issues on my mac - today I closed it to restart my computer and it gave the notice about finishing the last task and then will close… but the spinner kept spinning so after 5 or more minutes I just had it skip and quit.
Now I cannot get GarageSale to open. The icon bounces once or twice when I click it, but then stops without opening.
I’ve re-downloaded the latest version (8.3) again and reinstalled it and it still won’t open.
Mac is running Mojave (need to update…) but info says 8.3 runs on 10.12 and higher it was running with no issues on it before this evening
I have the pro version subscription.
Any insight on what might be causing this or how I can troubleshoot?
Same here on 10.14.6.
Sorry that I did not test the BETA versions, the crash happens on all of them, too (I checked out Beta 1, 3, 7, 8 now…) Next time I will help with the BETAs again, sorry, too much work at the moment…
