I had just listed several auction using GarageSale. Now when I go on it is continually shutting down automatically after a few seconds. Below is the report.
Version 7.0.16? You need to update to the latest version and refresh your token.
yes. currently have version 7.0.16. Unable to update version because it quits before I have a chance. Was working fine one minute then stopped working all of a sudden. Suggestion on how to update since keeps crashing?
The latest and reportedly last update is GarageSale 7.0.21. (Likely to break by ebay in january.) Go to GarageSale - Make your business on eBay and find 7.0.21 on the lower right under older versions, and download the latest update
