Hi, I downloaded the widget, I have met all the requirements but it doesn’t seem to want to launch.
Were you able to add the GarageSale Widget to your Dashboard screen? Is the GarageSale Widget listed as an available widget when your click the “+” button in Dashboard?
Yes after multiple tries it did add. Not sure what the deal was. Thank you.
