I just downloaded the new update and was prompted to install it. I did and now the app won’t open AT ALL!!! Please Help ASAP!!!
Is there any error message or crash report coming up after GarageSale failed to launch?
What version of macOS are you using?
Can you recall what version of GarageSale you have been running before?
I sorted it. The program was corrupted. I trashed it and downloaded it again.
