I have GarageSale 7.0.21 installed and recently find that it crashes on opening. I installed free version of GarageSale 9.0.5 and initially seemed to have imported database successfully on first use but subsequently crashes in the same manner.
Running MacOS Ventura 13.0.
I was going to re-install GarageSale 7 but wanted to backup my listings but cannot seem to find these either in Library.
Unfortunately does not stay open long enough, I have triggered a couple of fault logs that Inthi k were sent back to iwascoding; I will see if I can trigger again
Can you execute the following command in the Terminal application and send us the output? You will find the Terminal app in the /Applications/Utilities folder!
Sorry, it seems the crash is happening so early that the built-in crash catcher doesn’t have enough time to post it to the server.
If you are getting a crash report on your Mac, could you try posting it here again. Last time nothing came through. If you can’t post it here, please send it to garagesale@iwascoding.com, referring to this thread.
No crash log being generated but I now find if I switch off internet I can open Garage Sale 7 & 9 - sod please let me know information to retrieve from GarageSale 9?
While it’s true that GarageSale 7 would start when there’s no internet, GarageSale 9 should be fine with or without internet.
What happens if you try starting GarageSale 9 from the Terminal utility. Assuming you have GarageSale 9 installed as “GarageSale 9” on your Mac under Applications, please paste the line below into the Terminal utility (under /Applications/Utilities) and press return. Can please copy the output here afterwards?
