I think these blank spaces are what you call ghosts? And all the dotted line listings don’t exist in my listings only show in a search. Many are showing up in searches now in 9.2b2
Do these ghost listings appear in smart groups only?
Can you give this a try, please?:
Start GarageSale and immediately click and hold down the ctrl-key on your keyboard.
A small window should appear allowing you to enable “debug options”.
Select “Re-build indexes”, then hit Continue.
Give GarageSale some time to start up.
Restart GarageSale. Any better now?
No, They are Still there
Maybe more steps are required here:
Step A:
Select “Remove ghost children from groups” and “Find orphaned listings” in the “debug options” panel, then hit Continue.
Restart GarageSale
Step B:
Select “Re-build indexes” in the “debug options” panel, then hit Continue.
This cleaned up 29 of the blank listings with the "Lorem ipsum " and 100 some obscure listings ended and not in my folders but the search is still the same as the screen shot above. It’s not a big problem but they do clog up my searches for items.
buy a bigger screen? j/k
