Is it possible to bulk-edit listings with the new GS. On the old version one was able to select ten listings, for example, and change the duration for all listings selected. On the new version, when performing this function, only the first listing selected receives the duration change. Thank you.
After you select multiple listings on the left side of the screen, you then have to select all the listings on the right side of the screen that pop up. You’ll notice that only one of the listings will be highlighted by default, so you have to manually select them all. It’s annoying to have to do that extra step, but it works!
in the help there’s a short animation that shows how to bulk edit:
https://manual.iwascoding.com/gs7/en/Listings_Section-Bulk_Editing.html
Very annoying. I hate it and it seems pointless.
The link to the manual generates the following error:
Safari Can’t Find the Server
Safari can’t open the page “https://manual.iwascoding.com/gs7/en/Listings_ Section-Bulk_Editing.html” because Safari can’t find the server “manual.iwascoding.com”.
Hi Neal,
maybe it was just a temporary issue with the server?
I just tried it here in two browsers and it works like a charm.
Here’s the link again: https://manual.iwascoding.com/gs7/en/Listings_Section-Bulk_Editing.html
Yep. Works now. Thanx!
Thank you, this worked.
