Scrolling and paging-up or paging-down really is unusable…
It also pegs the WindowServer process at 100%+ CPU usage.
Just started when I upgraded to macOS 10.14.2 from 10.13.6 which worked fine.
iMac (Retina 5K, 27-inch, Late 2015)
4 GHz Intel Core i7
32 GB 1867 MHz DDR3
iMac SSD
AMD Radeon R9 M395 2048 MB
I have moved onto v8 which works good, but maybe this will show something in v7 that can also be optimized in v8???
There is something wrong with the re-drawing of the outline view cells, but from the samples you sent, I don’t know what’s causing it.
GarageSale spends it’s time in some system library calls that probably have to do with animations (hence your window server being at 100%), and almost no time in our own code.
Why this is happening in GarageSale 7 and not in GarageSale 8 is beyond me. The mechanism for drawing the outline view is the same, the only difference being that they are linked against different versions of the SDK.
I was really going with the upgrade to Mojave some days ago, then read your message and had some doubts… anyway this morning I will start to work on two machines, the iMac has Mojave and will check if it happens also to me. Until now I worked with transparency ON with Sierra and no problems at all… let’s check later. Anyway this is not the first time I hear about app problems due to transparency…
