Continuing the discussion from GS 8.1 not auto-updating new categories :
This just happened again…
Exactly the same behavior. Category says “Unknown”. Manually Selecting “Update Categories” downloads new categories, but does not automatically “update” the current listing template. Then I just need to select a different listing template, and select back and all is good.
Any way I can find the “current” dowloaded category version #??? Before the manual update and then after??? This would tell me if a newer version of the category data was actually loaded.
