Installed the Beta (9.9.3B (1720)) but still getting the popup (Safari Facebook) - any settings suggestions I should enable/disable?
Is it still this exact URL that opens in your Safari?: https://www.facebook.com/tr/
Yes that’s the URL – It is still happening under the beta for me as well
Yes - the /tr/ directory from Facebook - also impacts Chrome when I set it to Default Browser - if it helps I tend to see it right after listing or revising something - not always, but this seems to be a common time.
(UPDATED step 3 to 6:)
@mgerardn @sellersmack
To help us diagnose this further it would be super helpful, if you could provide with some logs. Please follow these steps:
Quit GarageSale, if running.
Open the “Terminal” application, paste in the following commands and hit the enter key:
defaults write com.iwascoding.garagesale9 logLevel 9
Open “Console” app (in Applications/Utilities), click on “Start Streaming”
Start GarageSale and trigger the Facebook page.
Go back to “Console” app again and search for
decidePolicyForWebViewNavigationAction -
Copy the output, save it into a Text file and post it here or send it to us. Thank you!
First:
decidePolicyForWebViewNavigationAction: [listener use]
Then:
decidePolicyForWebViewNavigationAction: {
WebActionModifierFlagsKey = 0;
WebActionNavigationTypeKey = 5;
WebActionOriginalURLKey = “about:blank”;
}, request: <NSMutableURLRequest: 0x600001542040> { URL: about:blank }
I’ll send a email with a live listing.
Hi. Did you receive the PDF
I just checked but I have not received your PDF, unfortunately. Feel free to send it to our support directly:
(Click on “Contact Support via Mail”)
@sellersmack @mgerardn Unfortunately, my initial instructions were unclear so I updated them in my post (step 3 to 6):
Could you please check the logs once again and send us the output (or post it here)?
please have a try with the following version and tell us whether this version fixes it for you:
Seems to be gone with this beta.
I too am having this Facebook page opening issue. I use Google Chrome though as compared to Firefox and Safari. I did try the Settings / Ebay / Advanced tweak as mentioned above but haven’t clicked on anything before coming here to type this reply. @kristian you mentioned a fix in a beta? Thanks for the help!
@jsnoah Please give the latest beta version of GarageSale 9.9.3 a try. You can download it here:
Since I’m not having this problem I’m fundamentally curious: What do you all think is happening here? Is it that I never have GS open a “live” auction at all? Or something external?
Mainly asking to avoid it happening in future.
Started happening to me about two weeks ago. So utterly annoying. I will try some of the recommendations in this thread. I use Chrome.
It should be fixed in the latest 9.9.3 beta version:
