GS Crashing on Startup
New M4 Mac Mini, GS has been working fine until this AM. Every time I start up the program it closes with a “Something unexpected…” error. Restarting the machine doesn’t result in any change in behavior.
My GS is 9.9 (1706)
MacOS crash dump attached.
I have an Intel Mac available so I can get around this for now.
gs_crash.txt (78.6 KB)
Can you please have a look at Paul’s answer here and give that solution a try?:
Deleted and re-installed GS 9.9 and same thing. Crashes on startup (every time).
As to Paul’s file deletion tip, that seemed to do the trick.
Thank you!
