I just noticed the little gray hint text below the Duration dropdown, which here says “Already started”, which is helpful!
However when I select another listing with exactly the same state it changes to “Multiple values”.
Literally every item in the box which is hinted is exactly the same!
I can reproduce the multiple values only when I choose 2 auctions at the same time. Do you only have 1 highlighted?
One auction the first time, two auctions the second time. But there are not “multiple values”.
Ah I see. I mean (first) I select one, (second) I add a second one to the selection.
It should probably say already started but I guess 2 makes it say multiple values even though both are 10 days
system
Closed
5
