I just upgraded to GS9 from GS7 recently like many here.
In GS7, I had absolutely NO problems with GS Scheduler.
Background:
Using GarageSale 9.0.5 (1436) on iMac with macOS Monterey.
Created an event with 15 listings in GS Scheduler.
First 3 listings in the event started without any problem. Rest of them failed/did not start.
Tried to manually start one of these failed listings. Started without any problems.
Created another event with these same failed listings.
These listings start without any problems - ONLY AS LONG AS THE SCREEN IS ON.
They all start to fail if the screen “locks”.
I can’t be expected to leave the screen on perpetually for whenever there is an GS event scheduled!
What if I have an event scheduled in a weeks time when I am away? Or in the middle of the night?
Am I expected to just leave the screen on all the time? That would be insane!
This was NOT a problem in GS7 so I don’t understand why it would be a problem in the “updated” version?
These are my iMac Energy settings and GS Preferences
Hi I have a similar problem with failed Scheduled listings; however all the failed listings on mine are showing a red error symbol under the automatic restart section - not something I have selected nor am i using this option.
Have you checked with the “Keychain Access” utility, that you don’t have the “Lock when sleeping” or “Lock after … minutes of inactivity” boxes checked for your “login” Keychain?
You need to control-click on the “login” keychain entry in the left-hand table, and choose “Change settings…”.
BUT leaving computer unprotected without password is NOT a solution.
GS 7 (which I was using absolutely without ANY problem at all till last week) had NO PROBLEMS to function when screen was password protected. I don’t understand why the same functionality / solution can’t implement in GS9?
The workaround presented above is just that - a half baked workaround. Not a solution.
Leaving any computer un-protected for days when I am travelling but have auctions scheduled is not an acceptable solution when asking us to pay a monthly fee.
