GS Scout Not Working!
As of today, GS Scout can no longer transfer listings and photos to GS on my Macbook the way it always has done.
Now the connection just times out before transferring the listings.
Please HELP!!
I can use my phone to take photos from inside a listing via the Take Photo option just fine.
I just cannot seem to get GS to get the photos from GS Scout with the Share with GarageSale function.
I just tried it here but for me the import from GarageSale Scouts still works super fine.
Can you post a screenshot of the timeout message that you get?
Also what version of GarageSale and macOS do you use?
Make sure that all devices are on the same WiFi network.
It might be that anything on your system or your system itself is blocking the connection, e.g. maybe you didn’t allow GarageSale network access. You can check this in the System Preferences > Privacy & Security > Local Network
Hi Kristian,
When I use my Wifi it freezes but when I connect my Macbook up to my phone’s hotspot connection everything transfers smoothly.
I have set up the network prefs on my Macbook to allow GS connectivity through the firewall.
Any ideas?
